A gradient estimator via L1-randomization for online zero-order optimization with two point feedback - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This work studies online zero-order optimization of convex and Lipschitz functions. We present a novel gradient estimator based on two function evaluations and randomization on the $\ell_1$-sphere. Considering different geometries of feasible sets and Lipschitz assumptions we analyse online dual averaging algorithm with our estimator in place of the usual gradient. We consider two types of assumptions on the noise of the zero-order oracle: canceling noise and adversarial noise. We provide an anytime and completely data-driven algorithm, which is adaptive to all parameters of the problem. In the case of canceling noise that was previously studied in the literature, our guarantees are either comparable or better than state-of-the-art bounds obtained by Duchi et al. (2015) and Shamir (2017) for non-adaptive algorithms. Our analysis is based on deriving a new weighted Poincar\'e type inequality for the uniform measure on the $\ell_1$-sphere with explicit constants, which may be of independent interest.
hal-03782218 , version 1 (21-09-2022)
Arya Akhavan, Evgenii Chzhen, Massimiliano Pontil, Alexandre B. Tsybakov. A gradient estimator via L1-randomization for online zero-order optimization with two point feedback. NeurIPS 2022 - Thirty-sixth Conference on Neural Information Processing Systems, Nov 2022, New Orleans, United States. ⟨hal-03782218⟩
39 Consultations
0 Téléchargements
