Reproducibility of motor task-based fNIRS and comparison with functional MRI in healthy adults
We studied the ability and reproducibility of fNIRS to map the cortical motor areas. Simultaneously acquired fMRI was used as a reference and functional maps of both modalities were obtained from GLM analysis. NIRS results show satisfactory reproducibility but partial agreement with fMRI.
fNIRS_2022_NolwennJegou.pdf (150.08 Ko)
Télécharger le fichier
rotatePosterV3.2.pdf (2.25 Mo)
