Characterizing Uncertainty in the Visual Text Analysis Pipeline - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Current visual text analysis approaches rely on sophisticated processing pipelines. Each step of such a pipeline potentially amplifies any uncertainties from the previous step. To ensure the comprehensibility and interoperability of the results, it is of paramount importance to clearly communicate the uncertainty not only of the output but also within the pipeline. In this paper, we characterize the sources of uncertainty along the visual text analysis pipeline. Within its three phases of labeling, modeling, and analysis, we identify six sources, discuss the type of uncertainty they create, and how they propagate. The goal of this paper is to bring the attention of the visualization community to additional types and sources of uncertainty in visual text analysis and to call for careful consideration, highlighting opportunities for future research.
TextVis_Uncertainty.pdf (235.25 Ko) Télécharger le fichier
Format : Figure, Image
Licence : CC BY NC - Paternité - Pas d'utilisation commerciale
hal-03784519 , version 1 (23-09-2022)
  • HAL Id : hal-03784519 , version 1
Pantea Haghighatkhah, Mennatallah El-Assady, Jean-Daniel Fekete, Narges Mahyar, Carita Paradis, et al.. Characterizing Uncertainty in the Visual Text Analysis Pipeline. VIS4DH 2022 - 7th Workshop on Visualization for the Digital Humanities, Oct 2022, Oklahoma City, United States. ⟨hal-03784519⟩
73 Consultations
126 Téléchargements
