Parameter Synthesis for Parametric Probabilistic Dynamical Systems and Prefix-Independent Specifications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider the model-checking problem for parametric probabilistic dynamical systems, formalised as Markov chains with parametric transition functions, analysed under the distribution-transformer semantics (in which a Markov chain induces a sequence of distributions over states). We examine the problem of synthesising the set of parameter valuations of a parametric Markov chain such that the orbits of induced state distributions satisfy a prefix-independent ω-regular property. Our main result establishes that in all non-degenerate instances, the feasible set of parameters is (up to a null set) semialgebraic, and can moreover be computed (in polynomial time assuming that the ambient dimension, corresponding to the number of states of the Markov chain, is fixed).
parametric-synthesis22.pdf (880.65 Ko) Télécharger le fichier
hal-03789856 , version 1 (27-09-2022)
Christel Baier, Florian Funke, Simon Jantsch, Toghrul Karimov, Engel Lefaucheux, et al.. Parameter Synthesis for Parametric Probabilistic Dynamical Systems and Prefix-Independent Specifications. 33rd International Conference on Concurrency Theory (CONCUR 2022), Sep 2022, Varsovie, Poland. ⟨10.4230/LIPIcs.CONCUR.2022.10⟩. ⟨hal-03789856⟩
63 Consultations
44 Téléchargements
