From geodesic extrapolation to a variational BDF2 scheme for Wasserstein gradient flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics of Computation Année : 2024
We introduce a time discretization for Wasserstein gradient flows based on the classical Backward Differentiation Formula of order two. The main building block of the scheme is the notion of geodesic extrapolation in the Wasserstein space, which in general is not uniquely defined. We propose several possible definitions for such an operation, and we prove convergence of the resulting scheme to the limit PDE, in the case of the Fokker-Planck equation. For a specific choice of extrapolation we also prove a more general result, that is convergence towards EVI flows. Finally, we propose a variational finite volume discretization of the scheme which numerically achieves second order accuracy in both space and time.
WassersteinExtrapolationBDF2.pdf (2.47 Mo) Télécharger le fichier
hal-03790981 , version 1 (28-09-2022)
hal-03790981 , version 2 (30-05-2023)
hal-03790981 , version 3 (18-10-2023)
Thomas Gallouët, Andrea Natale, Gabriele Todeschi. From geodesic extrapolation to a variational BDF2 scheme for Wasserstein gradient flows. Mathematics of Computation, 2024, ⟨10.1090/mcom/3951⟩. ⟨hal-03790981v3⟩
177 Consultations
72 Téléchargements
