Unsupervised Echocardiography Registration through Patch-based MLPs and Transformers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Image registration is an essential but challenging task in medical image computing, especially for echocardiography, where the anatomical structures are relatively noisy compared to other imaging modalities. Traditional (non-learning) registration approaches rely on the iterative optimization of a similarity metric which is usually costly in time complexity. In recent years, convolutional neural network (CNN) based image registration methods have shown good effectiveness. In the meantime, recent studies show that the attention-based model (e.g., Transformer) can bring superior performance in pattern recognition tasks. In contrast, whether the superior performance of the Transformer comes from the long-winded architecture or is attributed to the use of patches for dividing the inputs is unclear yet. This work introduces three patch-based frameworks for image registration using MLPs and transformers. We provide experiments on 2D-echocardiography registration to answer the former question partially and provide a benchmark solution. Our results on a large public 2D-echocardiography dataset show that the patch-based MLP/Transformer model can be effectively used for unsupervised echocardiography registration. They demonstrate comparable and even better registration performance than a popular CNN registration model. In particular, patch-based models better preserve volume changes in terms of Jacobian determinants, thus generating robust registration fields with less unrealistic deformation. Our results demonstrate that patch-based learning methods, whether with attention or not, can perform high-performance unsupervised registration tasks with adequate time and space complexity.
REG_STACOM2022.pdf (582.25 Ko) Télécharger le fichier
hal-03792276 , version 1 (30-09-2022)
  • HAL Id : hal-03792276 , version 1
Zihao Wang, Yingyu Yang, Maxime Sermesant, Hervé Delingette. Unsupervised Echocardiography Registration through Patch-based MLPs and Transformers. STACOM 2022 - 13th workshop on Statistical Atlases and Computational Models of the Heart, Sep 2022, Singapore, Singapore. ⟨hal-03792276⟩
73 Consultations
130 Téléchargements
