Ivo G. Rosenberg's Special Issue - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
N°Spécial De Revue/Special Issue Journal of Multiple-Valued Logic and Soft Computing Année : 2022
Miguel Couceiro
Maurice Pouzet
  • Fonction : Auteur
  • PersonId : 830436
Lucien Haddad
  • Fonction : Auteur
  • PersonId : 1005787
This first volume is dedicated to the memory of the late Professor Ivo G. Rosenberg (1934-2018) that is missed and recalled by the universal algebra and multiple valued logic communities not only as one of the greatest mathematicians of our time, but also as a wonderful human being. It is made of seven contributions that cover some of the many research interests of Ivo that include finite and infinite posets, lattices, tolerances, combinatorial properties of finite sets, matrices over lattices, and quasigroups and semigroups.
main.pdf (97.3 Ko) Télécharger le fichier
hal-03792732 , version 1 (30-09-2022)
  • HAL Id : hal-03792732 , version 1
Miguel Couceiro, Maurice Pouzet, Lucien Haddad. Ivo G. Rosenberg's Special Issue. Miguel Couceiro; Lucien Haddad; Maurice Pouzet. Journal of Multiple-Valued Logic and Soft Computing, 39 (1), 2022, Ivo G. Rosenberg's Special Issue. ⟨hal-03792732⟩
13 Consultations
16 Téléchargements
