Hash Gone Bad: Automated discovery of protocol attacks that exploit hash function weaknesses - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Most cryptographic protocols use cryptographic hash functions as a building block. The security analyses of these protocols typically assume that the hash functions are perfect (such as in the random oracle model). However, in practice, most widely deployed hash functions are far from perfect-and as a result, the analysis may miss attacks that exploit the gap between the model and the actual hash function used. We develop the first methodology to systematically discover attacks on security protocols that exploit weaknesses in widely deployed hash functions. We achieve this by revisiting the gap between theoretical properties of hash functions and the weaknesses of real-world hash functions, from which we develop a lattice of threat models. For all of these threat models, we develop fine-grained symbolic models. Our methodology's fine-grained models cannot be directly encoded in existing state-of-the-art analysis tools by just using their equational reasoning. We therefore develop extensions for the two leading tools, TAMARIN and PROVERIF. In extensive case studies using our methodology, the extended tools rediscover all attacks that were previously reported for these protocols and discover several new variants.
eprint.pdf (328.17 Ko) Télécharger le fichier
hal-03795715 , version 1 (04-10-2022)
  • HAL Id : hal-03795715 , version 1
Vincent Cheval, Cas Cremers, Alexander Dax, Lucca Hirschi, Charlie Jacomme, et al.. Hash Gone Bad: Automated discovery of protocol attacks that exploit hash function weaknesses. 32nd USENIX Security Symposium, Aug 2023, Anaheim, United States. ⟨hal-03795715⟩
433 Consultations
225 Téléchargements
