Practical and sound equality tests, automatically -- Deriving eqType instances for Jasmin's data types with Coq-Elpi - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we describe the design and implementation of feqb, a tool that synthesizes sound equality tests for inductive data types in the dependent type theory of the Coq system. Our procedure scales to large inductive data types, as in hundreds of constructors, since the terms and proofs it synthesizes are linear in the size of the inductive type. Moreover it supports some forms of dependently typed arguments and sigma types pairing data with proofs of decidable properties. Finally feqb handles deeply nested containers without requiring any human intervention.
feqb.pdf (581.41 Ko) Télécharger le fichier
hal-03800154 , version 1 (06-10-2022)
Paternité
Benjamin Grégoire, Jean-Christophe Léchenet, Enrico Tassi. Practical and sound equality tests, automatically -- Deriving eqType instances for Jasmin's data types with Coq-Elpi. CPP '23: 12th ACM SIGPLAN International Conference on Certified Programs and Proofs, Jan 2023, Boston MA USA, France. pp.167-181, ⟨10.1145/3573105.3575683⟩. ⟨hal-03800154⟩
149 Consultations
234 Téléchargements
