A SUR version of the Bichon criterion for excursion set estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2022
Introduction to the inversion framework Motivation: many inversion issues are present in industry [El Amri, 2019]. Goal: find all sets of parameters such that a quantity of interest remains below a threshold. Mathematical Formulation: estimation of the following Γ set while limiting the number of g black-box evaluations: Γ := x ∈ X, g(x) ≤ T (1) with X ⊂ R d design space (compact) and T threshold. Application (floating wind turbine): pre-calibration step consists in estimating model parameters that fit the measured data.
Poster Session Mascot Num 2022 Duhamel.pdf (283.26 Ko) Télécharger le fichier
hal-03806245 , version 1 (07-10-2022)
  • HAL Id : hal-03806245 , version 1
Clément Duhamel, Clémentine Prieur, Céline Helbert, Miguel Munoz Zuniga, Delphine Sinoquet. A SUR version of the Bichon criterion for excursion set estimation. Mascot Num 2022 -Annual GdR meeting, Jun 2022, Clermont-Ferrand, France. pp.1-1. ⟨hal-03806245⟩
103 Consultations
59 Téléchargements
