Applying GMRES to the Helmholtz equation with strong trapping: how does the number of iterations depend on the frequency? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advances in Computational Mathematics Année : 2022
We consider GMRES applied to discretisations of the high-frequency Helmholtz equation with strong trapping; recall that in this situation the problem is exponentially ill-conditioned through an increasing sequence of frequencies. Under certain assumptions about the distribution of the eigenvalues, we prove upper bounds on how the number of GMRES iterations grows with the frequency. Our main focus is on boundary-integral-equation formulations of the exterior Dirichlet and Neumann obstacle problems in 2- and 3-d; for these problems, we investigate numerically the sharpness (in terms of dependence on frequency) of both our bounds and various quantities entering our bounds. This paper is therefore the first comprehensive study of the frequency-dependence of the number of GMRES iterations for Helmholtz boundary-integral equations under trapping.
hal-03810288 , version 1 (11-10-2022)
Pierre Marchand, Jeffrey Galkowski, Alastair Spence, Euan A. Spence. Applying GMRES to the Helmholtz equation with strong trapping: how does the number of iterations depend on the frequency?. Advances in Computational Mathematics, 2022, 48 (4), ⟨10.1007/s10444-022-09931-9⟩. ⟨hal-03810288⟩
Collections
INSMI TDS-MACS
38 Consultations
0 Téléchargements
