Making a guitar rack plugin -WebAudio Modules 2.0 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
WebAudio Modules 2.0 (aka WAM) is a standard for developing interoperable host and plugins. that can be written using different development approaches (JavaScript, build systems, TypeScript, FAUST, Csound, front-end frameworks, etc.). In addition, the WAM standard includes the notion of group of plugins, in order for example to send MIDI events to a group of plugins or to unify their parameters in a single set. The demo we propose is about a plugin that acts as a host, that exploits the WAM group feature of the WAM SDK and manages a set of plugins. This plugin regroups guitar pedal effects and tube amp simulators plugins to propose a large set of sound presets organized in banks. It can be loaded by any WAM compatible 1 https://github.com/webaudiomodules and https://www.npmjs.com/settings/webaudiomodules/packages host, be it a single HTML page with a few lines of JavaScript or a complete DAW. Both cases will be demonstrated.
WAC_2022_paper_25.pdf (425.18 Ko) Télécharger le fichier
hal-03812948 , version 1 (13-10-2022)
  • HAL Id : hal-03812948 , version 1
Michel Buffa, Pierre Kouyoumdjian, Quentin Beauchet, Yann Forner, Michael Marynowic. Making a guitar rack plugin -WebAudio Modules 2.0. Web Audio Conference 2022, Jul 2022, Cannes, France. ⟨hal-03812948⟩
61 Consultations
299 Téléchargements
