Anytime Performance Assessment in Blackbox Optimization Benchmarking - Archive ouverte HAL Access content directly
Journal Articles IEEE Transactions on Evolutionary Computation Year : 2022
We present concepts and recipes for the anytime performance assessment when benchmarking optimization algorithms in a blackbox scenario. We consider runtime-oftentimes measured in number of blackbox evaluations needed to reach a target quality-to be a universally measurable cost for solving a problem. Starting from the graph that depicts the solution quality versus runtime, we argue that runtime is the only performance measure with a generic, meaningful, and quantitative interpretation. Hence, our assessment is solely based on runtime measurements. We discuss proper choices for solution quality indicators in single-and multiobjective optimization, as well as in the presence of noise and constraints. We also discuss the choice of the target values, budget-based targets, and the aggregation of runtimes by using simulated restarts, averages, and empirical cumulative distributions which generalize convergence graphs of single runs. The presented performance assessment is to a large extent implemented in the comparing continuous optimizers (COCO) platform freely available at https://github.com/numbbo/coco.
coco-perf-assess-paper.pdf (1.05 Mo) Télécharger le fichier
Dates and versions
hal-03814997 , version 1 (14-10-2022)
hal-03814997 , version 2 (31-01-2023)
Identifiers
Cite
Nikolaus Hansen, Anne Auger, Dimo Brockhoff, Tea Tusar. Anytime Performance Assessment in Blackbox Optimization Benchmarking. IEEE Transactions on Evolutionary Computation, 2022, 26 (6), pp.1293--1305. ⟨10.1109/TEVC.2022.3210897⟩. ⟨hal-03814997v2⟩
33 View
42 Download
Share
