Stability results for the KdV equation with time-varying delay - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Systems and Control Letters Année : 2023
In this paper, we consider the Korteweg-de Vries equation with time-dependent delay on the boundary or internal feedbacks. Under some assumptions on the timedependent delay, on the weights of the feedbacks and on the length of the spatial domain, we prove the exponential stability results, using appropriate Lyapunov functionals. We finish by some numerical simulations that illustrate the stability results and the influence of the delay on the decay rate.
kdv_tvdelay.pdf (857.16 Ko) Télécharger le fichier
hal-03819356 , version 1 (18-10-2022)
hal-03819356 , version 2 (07-07-2023)
Hugo Parada, Chahnaz Timimoun, Julie Valein. Stability results for the KdV equation with time-varying delay. Systems and Control Letters, 2023, 177, pp.105547. ⟨10.1016/j.sysconle.2023.105547⟩. ⟨hal-03819356v2⟩
180 Consultations
137 Téléchargements
