Factorized structure of the long-range two-electron integrals tensor and its application in quantum chemistry - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
We introduce two new approximation methods for the numerical evaluation of the long-range Coulomb potential and the approximation of the resulting high dimensional Two-Electron Integrals tensor (TEI) with long-range interactions arising in molecular simulations. The first method exploits the tensorized structure of the compressed two-electron integrals obtained through two-dimensional Chebyshev interpolation combined with Gaussian quadrature. The second method is based on the Fast Multipole Method (FMM). Numerical experiments for different medium size molecules on high quality basis sets outline the efficiency of the two methods. Detailed algorithmic is provided in this paper as well as numerical comparison of the introduced approaches.
template.pdf (5.01 Mo) Télécharger le fichier
hal-03826012 , version 1 (23-10-2022)
  • HAL Id : hal-03826012 , version 1
Siwar Badreddine, Igor Chollet, Laura Grigori. Factorized structure of the long-range two-electron integrals tensor and its application in quantum chemistry. 2022. ⟨hal-03826012⟩
136 Consultations
39 Téléchargements
