Analysis of the Anderson operator - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
We consider the continuous Anderson operator $H=\Delta+\xi$ on a two dimensional closed Riemannian manifold $\mathcal{S}$. We provide a short self-contained functional analysis construction of the operator as an unbounded operator on $L^2(\mathcal{S})$ and give almost sure spectral gap estimates under mild geometric assumptions on the Riemannian manifold. We prove a sharp Gaussian small time asymptotic for the heat kernel of $H$ that leads amongst others to strong norm estimates for quasimodes. We introduce a new random field, called Anderson Gaussian free field, and prove that the law of its random partition function characterizes the law of the spectrum of $H$. We also give a simple and short construction of the polymer measure on path space and relate the Wick square of the Anderson Gaussian free field to the occupation measure of a Poisson process of loops of polymer paths. We further prove large deviation results for the polymer measure and its bridges.
hal-03829755 , version 1 (25-10-2022)
Ismaël Bailleul, Nguyen Viet Dang, Antoine Mouzard. Analysis of the Anderson operator. 2022. ⟨hal-03829755⟩
87 Consultations
0 Téléchargements
