Graphon Mean-Field Backward Stochastic Differential Equations With Jumps and Associated Dynamic Risk Measures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail (Preprint/Prepublication) Année : 2022
Hamed Amini
  • Fonction : Auteur
  • PersonId : 1179136
Agnès Sulem
  • Fonction : Auteur
  • PersonId : 865285
We study graphon mean-field backward stochastic differential equations (BSDEs) with jumps and associated dynamic risk measures. We establish the existence, uniqueness and measurability of solutions under some regularity assumptions and provide some estimates for the solutions. We moreover prove the stability with respect to an interacting graphon particle systems, and obtain the convergence of an interacting mean-field particle system with inhomogeneous interactions to the graphon mean-field BSDE. We then provide some comparison theorems for the graphon mean-field BSDEs. As an application, we introduce the graphon dynamic risk measure induced by the solution of a graphon mean-field BSDE system and study its properties. We finally provide a dual representation theorem for the graphon dynamic risk measure in the convex case.
Fichier non déposé
hal-03830110 , version 1 (26-10-2022)
Hamed Amini, Zhongyuan Cao, Agnès Sulem. Graphon Mean-Field Backward Stochastic Differential Equations With Jumps and Associated Dynamic Risk Measures. 2022. ⟨hal-03830110⟩
120 Consultations
0 Téléchargements
