Choosing Answers in epsilon-Best-Answer Identification for Linear Bandits - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rémy Degenne
  • Fonction : Auteur
  • PersonId : 748911
  • IdHAL : remydegenne
Marc Jourdan
In pure-exploration problems, information is gathered sequentially to answer a question on the stochastic environment. While best-arm identification for linear bandits has been extensively studied in recent years, few works have been dedicated to identifying one arm that is $\varepsilon$-close to the best one (and not exactly the best one). In this problem with several correct answers, an identification algorithm should focus on one candidate among those answers and verify that it is correct. We demonstrate that picking the answer with highest mean does not allow an algorithm to reach asymptotic optimality in terms of expected sample complexity. Instead, a \textit{furthest answer} should be identified. Using that insight to choose the candidate answer carefully, we develop a simple procedure to adapt best-arm identification algorithms to tackle $\varepsilon$-best-answer identification in transductive linear stochastic bandits. Finally, we propose an asymptotically optimal algorithm for this setting, which is shown to achieve competitive empirical performance against existing modified best-arm identification algorithms.
hal-03830700 , version 1 (26-10-2022)
Rémy Degenne, Marc Jourdan. Choosing Answers in epsilon-Best-Answer Identification for Linear Bandits. 39th International Conference on Machine Learning (ICML 2022), Jul 2022, Baltimore, United States. ⟨hal-03830700⟩
20 Consultations
0 Téléchargements
