SRFeat: Learning Locally Accurate and Globally Consistent Non-Rigid Shape Correspondence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work, we present a novel learning-based framework that combines the local accuracy of contrastive learning with the global consistency of geometric approaches, for robust non-rigid matching. We first observe that while contrastive learning can lead to powerful point-wise features, the learned correspondences commonly lack smoothness and consistency, owing to the purely combinatorial nature of the standard contrastive losses. To overcome this limitation we propose to boost contrastive feature learning with two types of smoothness regularization that inject geometric information into correspondence learning. With this novel combination in hand, the resulting features are both highly discriminative across individual points, and, at the same time, lead to robust and consistent correspondences, through simple proximity queries. Our framework is general and is applicable to local feature learning in both the 3D and 2D domains. We demonstrate the superiority of our approach through extensive experiments on a wide range of challenging matching benchmarks, including 3D non-rigid shape correspondence and 2D image keypoint matching.
hal-03831098 , version 1 (26-10-2022)
Lei Li, Souhaib Attaiki, Maks Ovsjanikov. SRFeat: Learning Locally Accurate and Globally Consistent Non-Rigid Shape Correspondence. 3DV 2022 - International Conference on 3D Vision, Sep 2022, Prague / Hybrid, Czech Republic. ⟨hal-03831098⟩
33 Consultations
0 Téléchargements
