Temporal Dynamics of the Scale for the Assessment and Rating of Ataxia in Spinocerebellar Ataxias
Background
The Scale for the Assessment and Rating of Ataxia (SARA) is the reference clinical scale to assess the severity of cerebellar ataxia. In the context of upcoming therapeutic trials, a reliable clinical outcome is needed to assess the efficiency of treatments.
Objective
The aim is to precisely assess and compare temporal dynamics of SARA and a new f-SARA.
Methods
We analyzed data from four cohorts (EUROSCA, RISCA, CRC-SCA, and SPATAX) comprising 1210 participants and 4092 visits. The linearity of the progression and the variability were assessed using an ordinal Bayesian mixed-effect model (Leaspy). We performed sample size calculations for therapeutic trials with different scenarios to improve the responsiveness of the scale.
Results
Seven of the eight different items had a nonlinear progression. The speed of progression was different between most of the items, with an average time for a one-point increase from 3.5 years [3.4; 3.6] (median, 95% credible interval) for the fastest item to 11.4 [10.9; 12.0] years. The total SARA score had a linear progression with an average time for a one-point increase of 0.95 [0.92; 0.98] years. After removing the four last items and rescaling all items from 0 to 4, variability increased and progression was slower and thus would require a larger sample size in a future therapeutic trial.
Conclusion
Despite a heterogeneous temporal dynamics at the item level, the global progression of SARA was linear. Changing the initial scale deteriorates the responsiveness. This new information about the temporal dynamics of the scale should help design the outcome of future clinical trials.
Movement Disorders - 2022 - Moulaire - Temporal Dynamics of the Scale for the Assessment and Rating of Ataxia in.pdf (1.88 Mo)
Télécharger le fichier
