Flux approximation on unfitted meshes and application to multiscale hybrid-mixed methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail (Working Paper) Année : 2022
The flux variable determines the approximation quality of hybridizationbased numerical methods. This work proves that approximating flux variables in discontinuous polynomial spaces from the L2 orthogonal projection is super-convergent on meshes that are not aligned with jumping coefficient interfaces. The results assume only the local regularity of exact solutions in physical partitions. Based on the proposed flux approximation, we demonstrate that the mixed hybrid multiscale (MHM) finite element method is superconvergent in unfitted meshes, supporting the numerics presented in MHM seminal works.
chaumontfrelet_paredes_valentin_2022a.pdf (336.31 Ko) Télécharger le fichier
hal-03834748 , version 1 (31-10-2022)
  • HAL Id : hal-03834748 , version 1
Théophile Chaumont-Frelet, Diego Paredes, Frédéric Valentin. Flux approximation on unfitted meshes and application to multiscale hybrid-mixed methods. 2022. ⟨hal-03834748⟩
101 Consultations
58 Téléchargements
