CD8 memory precursor cell generation is a continuous process - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue iScience Année : 2022
Shaoying Wang
  • Fonction : Auteur
  • PersonId : 1255088
  • IdRef : 26307790X
Simon de Bernard
  • Fonction : Auteur
Arnaud Bonnaffoux
  • Fonction : Auteur
Fabien Crauste
In this work, we studied the generation of memory precursor cells following an acute infection by analyzing single-cell RNA-seq data that contained CD8 T cells collected during the postinfection expansion phase. We used different tools to reconstruct the developmental trajectory that CD8 T cells followed after activation. Cells that exhibited a memory precursor signature were identified and positioned on this trajectory. We found that these memory precursors are generated continuously with increasing numbers arising over time. Similarly, expression of genes associated with effector functions was also found to be raised in memory precursors at later time points. The ability of cells to enter quiescence and differentiate into memory cells was confirmed by BrdU pulse-chase experiment in vivo. Analysis of cell counts indicates that the vast majority of memory cells are generated at later time points from cells that have extensively divided.
PIIS2589004222011993.pdf (4.23 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-03842898 , version 1 (08-11-2022)
Helena Todorov, Margaux Prieux, Daphne Laubreton, Matteo Bouvier, Shaoying Wang, et al.. CD8 memory precursor cell generation is a continuous process. iScience, 2022, 25 (9), pp.104927. ⟨10.1016/j.isci.2022.104927⟩. ⟨hal-03842898⟩
147 Consultations
33 Téléchargements
