Efficient Association of Low and High RF Power Rectifiers for Powering Ultra-Low Power Devices
Nowadays, the efficiency of Radio Frequency (RF) energy harvesting circuits is continuously increasing and, at the same time, the energy consumption of connected devices is drastically decreasing. Despite that, collecting, storing and delivering such kind of harvested energy to the device in an appropriate manner is still a challenge. This paper presents the design of a harvester able to efficiently collect energy from both low and high power levels of the RF field. The objective is to correctly power supply an ultra-low power consumption device requiring a regulated voltage. A RF harvester circuit, specially designed for our application and consisting in the association of a low and a high level power rectifier, is presented. By the means of a circulator and depending on the RF power level received at the input port of the RF harvester circuit, the RF power is absorbed by the low power rectifier or reflected to the high power rectifier. The rectifiers have their outputs associated in series. At a frequency of 868 MHz, the efficiencies of the association of rectifiers are 43 % and 76 % and were obtained for input powers of-20 dBm and 0 dBm respectively.
