Formal reasoning about layered monadic interpreters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proceedings of the ACM on Programming Languages Année : 2022
Monadic computations built by interpreting, or handling , operations of a free monad are a compelling formalism for modeling language semantics and defining the behaviors of effectful systems. The resulting layered semantics offer the promise of modular reasoning principles based on the equational theory of the underlying monads. However, there are a number of obstacles to using such layered interpreters in practice. With more layers comes more boilerplate and glue code needed to define the monads and interpreters involved. That overhead is compounded by the need to define and justify the relational reasoning principles that characterize the equivalences at each layer. This paper addresses these problems by significantly extending the capabilities of the Coq interaction trees (ITrees) library, which supports layered monadic interpreters. We characterize a rich class of interpretable monads ---obtained by applying monad transformers to ITrees---and show how to generically lift interpreters through them. We also introduce a corresponding framework for relational reasoning about "equivalence of monads up to a relation R". This collection of typeclasses, instances, new reasoning principles, and tactics greatly generalizes the existing theory of the ITree library, eliminating large amounts of unwieldy boilerplate code and dramatically simplifying proofs.
hal-03850324 , version 1 (13-11-2022)
Irene Yoon, Yannick Zakowski, Steve Zdancewic. Formal reasoning about layered monadic interpreters. Proceedings of the ACM on Programming Languages, 2022, 6 (ICFP), pp.254-282. ⟨10.1145/3547630⟩. ⟨hal-03850324⟩
39 Consultations
0 Téléchargements
