A hybrid Reduced Basis and Machine-Learning algorithm for building Surrogate Models: a first application to electromagnetism - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A surrogate model approximates the outputs of a Partial Differential Equations (PDEs) solver with a low computational cost. In this article, we propose a method to build learning-based surrogates in the context of parameterized PDEs, which are PDEs that depend on a set of parameters but are also temporal and spatial processes. Our contribution is a method hybridizing the Proper Orthogonal Decomposition and several Support Vector Regression machines. We present promising results on a first electromagnetic use case (a primitive single-phase transformer).
Ribes-Persicot-Meyer-Ducreux-Workshop-ML4PS-NeurIPS_2022.pdf (413.43 Ko) Télécharger le fichier
hal-03850571 , version 1 (14-11-2022)
  • HAL Id : hal-03850571 , version 1
Alejandro Ribés, Ruben Persicot, Lucas Meyer, Jean-Pierre Ducreux. A hybrid Reduced Basis and Machine-Learning algorithm for building Surrogate Models: a first application to electromagnetism. Workshop on Machine Learning and the Physical Sciences workshop at NeurIPS 2022, Dec 2022, New Orleans, United States. pp.1-6. ⟨hal-03850571⟩
106 Consultations
84 Téléchargements
