Basic lambdas for C
We propose the inclusion of simple lambda expressions into the C standard. We build on a slightly restricted syntax of that feature in C++. In particular, they only have immutable value captures, fully specified parameter types, and, based on N2891, the return type is inferred from return statements. This is part of a series of papers for the improvement of type-generic programming in C for which the rationale is given in N2890. Follow-up papers N2894 and N2893 extend this feature with auto parameter types and default capture strategies, respectively.
Langage de programmation [cs.PL]
