Geometric Optimal Control of the Generalized Lotka-Volterra Model of the Intestinal Microbiome - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Optimal Control Applications and Methods Année : 2024
We introduce the theoretical framework from geometric optimal control for a control system modeled by the Generalized Lotka-Volterra (GLV) equation, motivated by restoring the gut microbiota infected by Clostridium difficile combining antibiotic treatment and fecal injection. We consider both permanent control and sampled-data control related to the medical protocols.
ocam-2022.pdf (2.2 Mo) Télécharger le fichier
hal-03861565 , version 1 (20-11-2022)
hal-03861565 , version 2 (06-02-2024)
Bernard Bonnard, Jérémy Rouot, Cristiana Silva. Geometric Optimal Control of the Generalized Lotka-Volterra Model of the Intestinal Microbiome. Optimal Control Applications and Methods, 2024, ⟨10.1002/oca.3089⟩. ⟨hal-03861565v2⟩
215 Consultations
135 Téléchargements
