On the Computation of Distributed Knowledge as the Greatest Lower Bound of Knowledge - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
Let $L$ be a finite lattice and $\mathcal{E}(L)$ be the set of join endomorphisms of $L$. We consider the problem of given $L$ and $f,g \in \mathcal{E}(L)$, finding the greatest lower bound $f \sqcap_{{\scriptsize \mathcal{E}(L)}} g$ in the lattice $\mathcal{E}(L)$. (1) We show that if $L$ is distributive, the problem can be solved in time $O(n)$ where $n=| L |$. The previous upper bound was $O(n^2)$. (2) We provide new algorithms for arbitrary lattices and give experimental evidence that they are significantly faster than the existing algorithm. (3) We characterize the standard notion of distributed knowledge of a group as the greatest lower bound of the join-endomorphisms representing the knowledge of each member of the group. (4) We show that deciding whether an agent has the distributed knowledge of two other agents can be computed in time $O(n^2)$ where $n$ is the size of the underlying set of states. (5) For the special case of $S5$ knowledge, we show that it can be decided in time $O(n\alpha_{n})$ where $\alpha_{n}$ is the inverse of the Ackermann function.
hal-03864537 , version 1 (21-11-2022)
Santiago Quintero, Carlos Pinzón, Sergio Ramírez, Frank Valencia. On the Computation of Distributed Knowledge as the Greatest Lower Bound of Knowledge. 2022. ⟨hal-03864537⟩
102 Consultations
0 Téléchargements
