StarPU profiling interface
This document introduces the programming interface exposed by the StarPU task-based parallel runtime system for performance monitoring tools to collect performance-related metrics on the execution of StarPU applications. It defines the entry point, the callback methods, the performance counters available. It also presents the usage of the mechanisms.
