The dynamics of Riemannian Robbins-Monro algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Many important learning algorithms, such as stochastic gradient methods, are often deployed to solve nonlinear problems on Riemannian manifolds. Motivated by these applications, we propose a family of Riemannian algorithms generalizing and extending the seminal stochastic approximation framework of Robbins and Monro. Compared to their Euclidean counterparts, Riemannian iterative algorithms are much less understood due to the lack of a global linear structure on the manifold. We overcome this difficulty by introducing an extended Fermi coordinate frame which allows us to map the asymptotic behavior of the proposed Riemannian Robbins-Monro (RRM) class of algorithms to that of an associated deterministic dynamical system under very mild assumptions on the underlying manifold. In so doing, we provide a general template of almost sure convergence results that mirrors and extends the existing theory for Euclidean Robbins-Monro schemes, albeit with a significantly more involved analysis that requires a number of new geometric ingredients. We showcase the flexibility of the proposed RRM framework by using it to establish the convergence of a retraction-based analogue of the popular optimistic / extra-gradient methods for solving minimization problems and games, and we provide a unified treatment for their convergence.
RRM-COLT.pdf (725.01 Ko) Télécharger le fichier
hal-03874052 , version 1 (27-11-2022)
Mohammad Reza Karimi, Ya-Ping Hsieh, Panayotis Mertikopoulos, Andreas Krause. The dynamics of Riemannian Robbins-Monro algorithms. COLT 2022 - 35th Annual Conference on Learning Theory, Jul 2022, London, United Kingdom. pp.1-31. ⟨hal-03874052⟩
53 Consultations
21 Téléchargements
