Cybersecurity of the Low Power Wide Area Networks (LPWAN) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Encyclopedia of Cryptography, Security and Privacy Année : 2022
Valeria Loscrì
  • Fonction : Auteur
  • PersonId : 1084587
Emilie Bout
  • Fonction : Auteur
  • PersonId : 1076684
Cyber-security of LPWAN is the analysis of vulnerability and potential threats for resource-constrained wireless connected objects. It also encompasses countermeasure approaches based on the identified vulnerabilities, that need to meet the computational and energy constraints.
Informatique
Cybersecurity LPWAN_Revised Version Nov.pdf (236.38 Ko) Télécharger le fichier
hal-03877629 , version 1 (29-11-2022)
  • HAL Id : hal-03877629 , version 1
Valeria Loscrì, Emilie Bout. Cybersecurity of the Low Power Wide Area Networks (LPWAN). Encyclopedia of Cryptography, Security and Privacy, 2022. ⟨hal-03877629⟩
Collections
INRIA INRIA2
60 Consultations
54 Téléchargements
