A viscoelastic flow model of maxwell-type with a symmetric-hyperbolic formulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail (Preprint/Prepublication) Année : 2022
Maxwell models for viscoelastic flows are famous for their potential to unify elastic motions of solids with viscous motions of liquids in the continuum mechanics perspective. But the usual Maxwell models allow one to define well motions mostly for one-dimensional flows only. To define unequivocal multi-dimensional viscoelastic flows (as solutions to well-posed initial-value problems) we advocated in [ESAIM:M2AN 55 (2021) 807-831] an upper-convected Maxwell model for compressible flows with a symmetrichyperbolic formulation. Here, that model is derived again, with new details.
cras.pdf (156.37 Ko) Télécharger le fichier
hal-03880001 , version 1 (02-12-2022)
Sébastien Boyaval. A viscoelastic flow model of maxwell-type with a symmetric-hyperbolic formulation. 2022. ⟨hal-03880001⟩
63 Consultations
57 Téléchargements
