Numerical resolution of the inverse source problem for EEG using the quasi-reversibility method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Inverse Problems Année : 2023
The paper concerns the numerical resolution of the inverse source problem for electroencephalography (EEG). We propose an approach which is able to take into account some heterogeneity properties (namely a varying electrical conductivity) of the head tissues, in particular of the skull layer. It combines two consecutive steps: (i) a data completion procedure from the scalp to the cortex using the quasi-reversibility (QR) method, (ii) a source estimation method from these cortical transmitted data within the brain (modeled as sphere), developed in the software tool FindSources3D (FS3D). Numerical simulations in the case of the multi-layered spherical head model illustrate both the promising and limiting features of the approach.
DLMT_R2.pdf (42.52 Mo) Télécharger le fichier
hal-03880526 , version 1 (01-12-2022)
hal-03880526 , version 2 (04-09-2023)
Paternité
Marion Darbas, Juliette Leblond, Jean-Paul Marmorat, Pierre-Henri Tournier. Numerical resolution of the inverse source problem for EEG using the quasi-reversibility method. Inverse Problems, 2023, 39 (11), pp.115003. ⟨10.1088/1361-6420/acf9c6⟩. ⟨hal-03880526v2⟩
107 Consultations
27 Téléchargements
