How to find a discrete entropy inequality when you don’t know if it exists - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail (Working Paper) Année : 2022
The solutions of hyperbolic systems contain discontinuities. These weak solutions verify not only the original PDEs, but also an entropy inequality that acts as a selection criterion determining whether a discontinuity is physical or not. Obtaining a discrete version of these entropy inequalities when approximating the solutions numerically is crucial to avoid convergence to unphysical solutions or even unstability. In this paper, we introduce an optimization framework that enable to quantify a posteriori entropy. We use it to obtain maps of numerical diffusion and to prove that some schemes do not have a discrete entropy inequality.
Fonctionnelle2.pdf (1.01 Mo) Télécharger le fichier
ConvergenceDiffusion-eps-converted-to.pdf (19.13 Ko) Télécharger le fichier
hal-03881570 , version 1 (02-12-2022)
  • HAL Id : hal-03881570 , version 1
Nina Aguillon, Emmanuel Audusse, Vivien Desveaux, Julien Salomon. How to find a discrete entropy inequality when you don’t know if it exists. 2022. ⟨hal-03881570⟩
224 Consultations
122 Téléchargements
