A Sorted Datalog Hammer for Supervisor Verification Conditions Modulo Simple Linear Arithmetic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Abstract In a previous paper, we have shown that clause sets belonging to the Horn Bernays-Schönfinkel fragment over simple linear real arithmetic (HBS(SLR)) can be translated into HBS clause sets over a finite set of first-order constants. The translation preserves validity and satisfiability and it is still applicable if we extend our input with positive universally or existentially quantified verification conditions (conjectures). We call this translation a Datalog hammer. The combination of its implementation in SPASS-SPL with the Datalog reasoner VLog establishes an effective way of deciding verification conditions in the Horn fragment. We verify supervisor code for two examples: a lane change assistant in a car and an electronic control unit of a supercharged combustion engine. In this paper, we improve our Datalog hammer in several ways: we generalize it to mixed real-integer arithmetic and finite first-order sorts; we extend the class of acceptable inequalities beyond variable bounds and positively grounded inequalities; and we significantly reduce the size of the hammer output by a soft typing discipline. We call the result the sorted Datalog hammer. It not only allows us to handle more complex supervisor code and to model already considered supervisor code more concisely, but it also improves our performance on real world benchmark examples. Finally, we replace the before file-based interface between SPASS-SPL and VLog by a close coupling resulting in a single executable binary.
hal-03881921 , version 1 (02-12-2022)
Martin Bromberger, Irina Dragoste, Rasha Faqeh, Christof Fetzer, Larry González, et al.. A Sorted Datalog Hammer for Supervisor Verification Conditions Modulo Simple Linear Arithmetic. Tools and Algorithms for the Construction and Analysis of Systems - 28th International Conference, TACAS 2022, Apr 2022, Munich (Germany), Germany. pp.480-501, ⟨10.1007/978-3-030-99524-9_27⟩. ⟨hal-03881921⟩
14 Consultations
0 Téléchargements
