A coupled model for the dynamics of gas exchanges in the human lung with Haldane and Bohr's effects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Theoretical Biology Année : 2023
We propose an integrated dynamical model for oxygen and carbon dioxide transfer from the lung into the blood, coupled with a lumped mechanical model for the ventilation process, for healthy patients as well as in pathological cases. In particular, we focus on the Bohr and Haldane effects, which induce a nonlinear coupling between the oxygen and the carbon dioxide. We also take into account the dead space volume, which requires a special attention in the pathological cases.
BoudinGrandmontGrecMartin_v2.pdf (1.92 Mo) Télécharger le fichier
hal-03883301 , version 1 (03-12-2022)
hal-03883301 , version 2 (01-09-2023)
Laurent Boudin, Céline Grandmont, Bérénice Grec, Sébastien Martin. A coupled model for the dynamics of gas exchanges in the human lung with Haldane and Bohr's effects. Journal of Theoretical Biology, In press, pp.111590. ⟨10.1016/j.jtbi.2023.111590⟩. ⟨hal-03883301v2⟩
165 Consultations
108 Téléchargements
