Using the FES framework to derive new physical degrees of freedom for finite element spaces of differential forms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advances in Computational Mathematics Année : 2023
In this paper we study a geometric approach for constructing physical degrees of freedom for sequences of finite element spaces. Within the framework of finite element systems, we propose new degrees of freedom for the spaces PrΛ k of polynomial differential forms and we verify numerically their unisolvence.
ArticleZampaAlonsoRapetti2021.pdf (417.15 Ko) Télécharger le fichier
hal-03884149 , version 1 (05-12-2022)
Enrico Zampa, Ana Alonso Rodríguez, Francesca Rapetti. Using the FES framework to derive new physical degrees of freedom for finite element spaces of differential forms. Advances in Computational Mathematics, 2023, 49 (2), pp.17. ⟨10.1007/s10444-022-10001-3⟩. ⟨hal-03884149⟩
75 Consultations
53 Téléchargements
