Online hierarchical forecasting for power consumption data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Forecasting Année : 2022
This paper proposes a three-step approach to forecasting time series of electricity consumption at different levels of household aggregation. These series are linked by hierarchical constraintsglobal consumption is the sum of regional consumption, for example. First, benchmark forecasts are generated for all series using generalized additive models; second, for each series, the aggregation algorithm 'polynomially weighted average forecaster with multiple learning rates', introduced by Gaillard, Stoltz and van Erven in 2014, finds an optimal linear combination of the benchmarks; finally, the forecasts are projected onto a coherent subspace to ensure that the final forecasts satisfy the hierarchical constraints. By minimizing a regret criterion, we show that the aggregation and projection steps improve the root mean square error of the forecasts. Our approach is tested on household electricity consumption data; experimental results suggest that successive aggregation and projection steps improve the benchmark forecasts at different levels of household aggregation.
articleIJF_underFinalReviews.pdf (978.33 Ko) Télécharger le fichier
hal-03884826 , version 1 (05-12-2022)
Margaux Brégère, Malo Huard. Online hierarchical forecasting for power consumption data. International Journal of Forecasting, 2022, 38 (1), pp.339-351. ⟨10.1016/j.ijforecast.2021.05.011⟩. ⟨hal-03884826⟩
27 Consultations
58 Téléchargements
