Discrete quantum harmonic oscillator and kravchuk transform - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
We consider a particular discretization of the harmonic oscillator which admits an orthogonal basis of eigenfunctions called Kravchuk functions possessing appealing properties from the numerical point of view. We analytically prove the almost second-order convergence of these discrete functions towards Hermite functions, uniformly for large numbers of modes. We then describe an efficient way to simulate these eigenfunctions and the corresponding transformation. We finally show some numerical experiments corroborating our different results.
kravchuk_final.pdf (954.75 Ko) Télécharger le fichier
hal-03885282 , version 1 (05-12-2022)
Quentin Chauleur, Erwan Faou. Discrete quantum harmonic oscillator and kravchuk transform. 2022. ⟨hal-03885282⟩
85 Consultations
76 Téléchargements
