A Design Space Exploration Framework for Memristor-Based Crossbar Architecture
In the literature, there are few studies describing how to implement Boolean logic functions as a memristor-based crossbar architecture and some solutions have been actually proposed targeting back-end synthesis. However, there is a lack of methodologies and tools for the synthesis automation. The main goal of this paper is to perform a Design Space Exploration (DSE) in order to analyze and compare the impact of the most used optimization algorithms on a memristor-based crossbar architecture. The results carried out on 102 circuits lead us to identify the best optimization approach, in terms of area/energy/delay. The presented results can also be considered as a reference (benchmarking) for comparing future work.
