High-dimensional variables clustering based on sub-asymptotic maxima of a weakly dependent random process - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The dependence structure between extreme observations can be complex. For that purpose, we see clustering as a tool for learning the complex extremal dependence structure. We introduce the Asymptotic Independent block (AI-block) model, a model-based clustering where population- level clusters are clearly defined using independence of clusters’ maxima of a multivariate random process. This class of models is identifiable allowing statistical inference. With a dedicated algorithm, we show that sample versions of the extremal correlation can be used to recover the clusters of variables without specifying the number of clusters. Our algorithm has a computational complexity that is polynomial in the dimension and it is shown to be strongly consistent in growing dimensions where observations are drawn from a stationary mixing process. This implies that groups can be learned in a completely nonparametric inference in the study of dependent processes where block maxima are only subasymptotic, i.e., approximately extreme value distributed.
Fichier non déposé
hal-03888395 , version 1 (07-12-2022)
  • HAL Id : hal-03888395 , version 1
Alexis Boulin, Elena Di Bernardino, Thomas Laloë, Gwladys Toulemonde. High-dimensional variables clustering based on sub-asymptotic maxima of a weakly dependent random process. CMStatistics 2022 - 15th International Conference of the ERCIM WG on Computational and Methodological Statistics, Dec 2022, London, United Kingdom. ⟨hal-03888395⟩
42 Consultations
0 Téléchargements
