A Coq Formalization of Lebesgue Induction Principle and Tonelli's Theorem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Lebesgue integration is a well-known mathematical tool, used for instance in probability theory, real analysis, and numerical mathematics. Thus, its formalization in a proof assistant is to be designed to fit different goals and projects. Once the Lebesgue integral is formally defined and the first lemmas are proved, the question of the convenience of the formalization naturally arises. To check it, a useful extension is Tonelli's theorem, stating that the (double) integral of a nonnegative measurable function of two variables can be computed by iterated integrals, and allowing to switch the order of integration. This article describes the formal definition and proof in Coq of product sigma-algebras, product measures and their uniqueness, the construction of iterated integrals, up to Tonelli's theorem. We also advertise the Lebesgue induction principle provided by an inductive type for nonnegative measurable functions.
article.pdf (426.85 Ko) Télécharger le fichier
hal-03889276 , version 1 (07-12-2022)
hal-03889276 , version 2 (16-12-2022)
Sylvie Boldo, François Clément, Vincent Martin, Micaela Mayero, Houda Mouhcine. A Coq Formalization of Lebesgue Induction Principle and Tonelli's Theorem. 25th International Symposium on Formal Methods (FM 2023), Mar 2023, Lübeck, Germany. pp.39--55, ⟨10.1007/978-3-031-27481-7_4⟩. ⟨hal-03889276v2⟩
262 Consultations
164 Téléchargements
