Mapping hydrodynamics for the facilitated exclusion and zero-range processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The Annals of Applied Probability Année : 2024
We derive the hydrodynamic limit for two degenerate lattice gases, the \emph{facilitated exclusion process} (FEP) and the \emph{facilitated zero-range process} (FZRP), both in the symmetric and the asymmetric case. For both processes, the hydrodynamic limit in the symmetric case takes the form of a diffusive Stefan problem, whereas the asymmetric case is characterized by a hyperbolic Stefan problem. Although the FZRP is attractive, a property that we extensively use to derive its hydrodynamic limits in both cases, the FEP is not. To derive the hydrodynamic limit for the latter, we exploit that of the zero-range process, together with a classical mapping between exclusion and zero-range processes, both at the microscopic and macroscopic level. Due to the degeneracy of both processes, the asymmetric case is a new result, but our work also provides a simpler proof than the one that was previously proposed for the FEP in the symmetric case in \cite{blondel2021stefan}.
Mapping_EX_ZR_Sym_and_Asym_4.pdf (545.5 Ko) Télécharger le fichier
hal-03889620 , version 1 (08-12-2022)
Clément Erignoux, Marielle Simon, Linjie Zhao. Mapping hydrodynamics for the facilitated exclusion and zero-range processes. The Annals of Applied Probability, In press. ⟨hal-03889620⟩
81 Consultations
41 Téléchargements
