Event-Triggered Control for Linear Time-Varying Systems Using a Positive Systems Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Systems and Control Letters Année : 2022
This paper presents a new design for the event-triggered output feedback control of uncertain linear time-varying systems. Departing from the traditional treatments of event-triggered linear time-invariant systems, it is shown that factoring of fundamental solutions as products of solutions of matrix differential equations, together with small-gain arguments and the notions of interval observers and positive systems, lead to a new class of robust event-triggered output-feedback controllers. A key innovation is our use of new event triggers, which use vectors of absolute values instead of the usual Euclidean 2-norms. An illustrative example of a curve tracking system from marine robotics validates the efficacy of the proposed design scheme.
Automatique
fmhalMMBJ22SCLCorr.pdf (394.47 Ko) Télécharger le fichier
hal-03891583 , version 1 (09-12-2022)
hal-03891583 , version 2 (23-07-2023)
Paternité
Frederic Mazenc, Michael Malisoff, Corina Barbalata, Zhong-Ping Jiang. Event-Triggered Control for Linear Time-Varying Systems Using a Positive Systems Approach. Systems and Control Letters, 2022, 161, pp.105131. ⟨10.1016/j.sysconle.2022.105131⟩. ⟨hal-03891583v2⟩
46 Consultations
48 Téléchargements
