An imperative programming language characterizing FBQP - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2022
We introduce an imperative programming language called QPT (Quantum Poly-Time) with recursion rules that captures the complexity class FBQP (Functions Bounded-error Quantum Polytime), the class of functions computable in polynomial time by a quantum Turing machine with at most 1/3 probability of error, commonly accepted as the class of feasible problems for quantum computers. Our result takes advantage of a function algebra proposed by Yamakami characterizing FBQP.
27Silva.pdf (537.99 Ko) Télécharger le fichier
hal-03895106 , version 1 (12-12-2022)
  • HAL Id : hal-03895106 , version 1
Emmanuel Hainry, Romain Péchoux, Mário Silva. An imperative programming language characterizing FBQP. QPL 2022 - Quantum Physics and Logic, Jun 2022, Oxford, United Kingdom. . ⟨hal-03895106⟩
43 Consultations
11 Téléchargements
