DIARITSup: a framework to supervise live measurements, Digital Twins modelscomputations and predictions for structures monitoring. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
DIARITsup is a chain of various softwares following the concept of "system of systems". It interconnects hardware and software layers dedicated to in-situ monitoring of structures or critical components. It embeds data assimilation capabilities combined with specific Physical or Statistical models like inverse thermal and/or mechanical ones up to the predictive ones. It aims at extracting and providing key parameters of interest for decision making tools. Its framework natively integrates data collection from local sources but also from external systems. DIARITsup is a milestone in our roadmap for SHM Digital Twins research framework. Furthermore, it intends providing some useful information for maintenance operations not only for surveyed targets but also for deployed sensors. Thanks to its Model-view-controller (MVC) design pattern, DIARITsup can be extended, customized and connected to existing applications. Its core component is made of a supervisor task that handles the gathering of data from local sensors and external sources like the open source meteorological data (observations and forecasts) from Météo-France Geoservice for instance. Meanwhile, a recorder manage the recording of all data and metadata in the Hierarchical Data Format (HDF5). HDF5 is used to its full potential with its Single-Writer-Multiple-Readers feature that enables a graphical user interface to represent the saved data in real-time, or the live computation of SHM Digital Twins models [3] for example. Furthermore, the flexibility of HDF5 data storage allows the recording of various type of sensors such as punctual sensors or full field ones. Finally, DIARITsup is able to handle massive deployment thanks to Ansible automation tool and a Gitlab synchronization for automatic updates. An overview of the developed software with a real application case will be presented. Perspectives towards improvements on the software with more component integrations (Copernicus Climate Data Store, etc.) and a more generic way to configure the acquisition and model configuration will be finally discussed.
Génie civil
EGU22-11201-print.pdf (292.78 Ko) Télécharger le fichier
hal-03895766 , version 1 (13-12-2022)
Jean Dumoulin, Thibaud Toullier, Mathieu Simon, Guillermo Andrade-Barroso. DIARITSup: a framework to supervise live measurements, Digital Twins modelscomputations and predictions for structures monitoring.. EGU General Assembly 2022, May 2022, Vienna, Austria. pp.1-2, ⟨10.5194/egusphere-egu22-11201⟩. ⟨hal-03895766⟩
11 Consultations
24 Téléchargements
