Study of adapted instrumentation architectures and measurements post-processing approaches for Infrared thermography applied to thermal monitoring in outdoor conditions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Technological progress in uncooled infrared focal plane array sensors has contributed significantly to enlarge the scope of applications of such sensing technique in many domains: Leisure, Manufacturing, Process Survey, Building insulation diagnostic, Civil Engineering, Road works, etc.. . Different outdoor situations and objects of interest monitored by an in-house designed measurement architecture are presented. Designed instrumentation architectures and measurements correction from varying environmental conditions and geometrical considerations are discussed. A first step toward joint estimation of emissivity and temperature is introduced for outdoor applications. Then moving object detection by an AI approach applied on thermal image sequences is also presented and discussed. Finally conclusion and perspectives are proposed.
SPIE_for_review.pdf (2.47 Mo) Télécharger le fichier
hal-03895839 , version 1 (13-12-2022)
Paternité
Jean Dumoulin, Thibaud Toullier, Laurent Mevel. Study of adapted instrumentation architectures and measurements post-processing approaches for Infrared thermography applied to thermal monitoring in outdoor conditions. 2022 - Infrared Remote Sensing and Instrumentation XXX, Aug 2022, San Diego, United States. pp.7, ⟨10.1117/12.2635258⟩. ⟨hal-03895839⟩
18 Consultations
35 Téléchargements
