Prospects of non-Cartesian 3D-SPARKLING encoding for functional MRI: A preliminary case study for retinotopic mapping - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
For the first time, non-Cartesian 3D-SPARKLING (Spreading Projection Algorithm for Rapid K-space sampLING) encoding scheme was used for taskbased fMRI (retinotopic mapping) at 7T. Additionally, this new acquisition technique was compared with 3D-EPI, considered as one of the reference acquisition schemes in high-resolution fMRI. The experiment was performed on a single participant at 1mm isotropic and for a temporal resolution of 2.4s. We found that both techniques yield similar statistically significant activation patterns in the visual cortex.
ViewSub1_ZainebAmor.pdf (1.19 Mo) Télécharger le fichier
hal-03901204 , version 1 (15-12-2022)
  • HAL Id : hal-03901204 , version 1
Zaineb Amor, Chaithya Giliyar Radhakrishna, Guillaume Daval-Frérot, Bertrand Thirion, Franck Mauconduit, et al.. Prospects of non-Cartesian 3D-SPARKLING encoding for functional MRI: A preliminary case study for retinotopic mapping. Joint Annual Meeting ISMRM-ESMRMB & ISMRT 31st Annual Meeting, May 2022, London, United Kingdom. ⟨hal-03901204⟩
52 Consultations
29 Téléchargements
