Synchronization of oscillators by nonlinear measurements with application to VLC - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This note studies the problem of masterslave phase synchronization between two oscillators described by Andronov-Hopf equations, where pulselike signals, which disturbances can be heavily corrupt, are used for communication. The synchronization conditions are established using the Lyapunov function theory, and the synchronization error bounds are evaluated. The results are motivated and illustrated by designing a synchronization scheme for visible light communication (VLC), where a periodic sequence is usually sent at the beginning of the communication to synchronize the transmitter and the receiver clocks.
VLC_CDC22_final.pdf (701.5 Ko) Télécharger le fichier
hal-03902230 , version 1 (23-03-2023)
  • HAL Id : hal-03902230 , version 1
Rosane Ushirobira, Denis Efimov, Antonio Costanzo, Valeria Loscri. Synchronization of oscillators by nonlinear measurements with application to VLC. CDC 2022 - 61th IEEE Conference on Decision and Control, IEEE, Dec 2022, Cancun, Mexico. ⟨hal-03902230⟩
51 Consultations
118 Téléchargements
