Particle resuspension: challenges and perspectives for future models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue (Article De Synthèse) Physics Reports Année : 2023
Using what has become a celebrated catchphrase, Philip W. Anderson once wrote that "more is different" (Science, Vol. 177, Issue 4047, pp. 393-396, 1972). First formulated in the context of condensed matter, this statement carries far beyond the sole limits of solid-state physics. It emphasizes that collective behavior can be more than the mere sum of what happens for elementary constituents or the mere collation of the evolution of each degree of freedom. Said otherwise, complex phenomena can arise out of the interplay between multiple sub-phenomena each of which can be relatively simple. The process of particle resuspension, in which discrete particles adhering on a surface are pulled off and carried away by a fluid flow, is another example involving a web of phenomena pertaining to fluid mechanics, particle dynamics and interface chemistry whose crosseffects create an intricate topic. The purpose of this review is to analyze the physics at play in particle resuspension in order to bring insights into the rich complexity of this common but challenging concern. Following the more-is-different vision, this is performed by starting from a range of practical observations and experimental data. We then work our way through the investigation of the key mechanisms which play a role in the overall process. In turn, these mechanisms reveal an array of fundamental interactions, such as particle-fluid, particle-particle and particle-surface, whose combined effects create the tapestry of current applications. At the core of this analysis are descriptions of these physical phenomena and the different ways through which they are intertwined to build up various models used to provide quantitative assessment of particle resuspension. The physics of particle resuspension implies to hold together processes occurring at extremely different space and time scales and models are key in providing a single vehicle to lead us through such multiscale journeys. This raises questions on what makes up a model and one objective of the present work is to clarify the essence of a modeling approach. In spite of its ubiquitous nature, particle resuspension is still at the early stages of developments. Many extensions need to be worked out and revisiting the art of modeling is not a moot point. The need to consider more complex objects than small and spherical particles and, moreover, to come up with unified descriptions of mono-and multilayer resuspension put the emphasis on solid model foundations if we are to go beyond current limits. This is very much modeling in the making and new ideas are proposed to stimulate interest into this everyday but challenging issue in physics.
2212.10151.pdf (27.43 Mo) Télécharger le fichier
hal-03909063 , version 1 (21-12-2022)
Christophe Henry, Jean-Pierre Minier, Sara Brambilla. Particle resuspension: challenges and perspectives for future models. Physics Reports, 2023, 1007, pp.1-98. ⟨10.1016/j.physrep.2022.12.005⟩. ⟨hal-03909063⟩
36 Consultations
128 Téléchargements
